MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
I was riding yesterday and realized my speedometer was just reading zero? It's a 2014 xf7000 cross country sno pro with 7300 miles. Shes been running like a top and still is...any suggestions? I looked for anything obvious on the trail but haven't had time to really dig into it yet. A quick search online only show possible magnet issue which I'm baffled how that could happen without messing with the chaincase. Maybe a bad sensor?
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Metal shavings on magnets in chain case or the sensor unglued from the chain case, perhaps a broken wire.
See if the sensor fell off the chaincase.
MyOutdoors
- May 4, 2003
- Lempster, NH
Lol..I was just coming in to mention it's an easy fix! It came off the exterior chaincase...now I just have to warm it up and epoxy it back on...anything recommended as far as epoxy or glue?See if the sensor fell off the chaincase.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I just used rtv silicone
MyOutdoors
- May 4, 2003
- Lempster, NH
I just used that as well...unfortunately I'm outside so I used a heat gun, warmed it up, cleaned it, warmed it again and lathered it up...hopefully it sticks well...either way...easy fix! thank you all for the heads up! I didn't get 1 response over at arctic chat.I just used rtv silicone
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Part of the reason why I ride Yamaha, mostly good people who want to help, not stupid remarks like fb , glad you found usI just used that as well...unfortunately I'm outside so I used a heat gun, warmed it up, cleaned it, warmed it again and lathered it up...hopefully it sticks well...either way...easy fix! thank you all for the heads up! I didn't get 1 response over at arctic chat.
robin94
- Jan 29, 2025
- Elliot Lake
- 2014 xf7000
Hey, do you still have this sled? I realize it's an old thread, but I believe I have the same issue, all is working except the speedometer. Would you have pictures of where the issue is located? ThanksLol..I was just coming in to mention it's an easy fix! It came off the exterior chaincase...now I just have to warm it up and epoxy it back on...anything recommended as far as epoxy or glue?
CCCT
- Jan 9, 2017
- Barrie/Sudbury/Muskoka
- 2007 Apex
2009 PhazerGT
Check this thread: https://ty4stroke.com/threads/help-sensor-fell-out.158993/Hey, do you still have this sled? I realize it's an old thread, but I believe I have the same issue, all is working except the speedometer. Would you have pictures of where the issue is located? Thanks
Just silicone the pad back on in the "slot" (see thread).
Angus viper
- Jun 29, 2007
- SW Ontario
- 2015 sr viper se
