chico619
- Dec 20, 2013
has any one else had the chain case up date done? when got back from dealer with update done the chain whines in the chain case! never did this before with 177 miles on it! now as soon as you drive it the noise is there!
DeerHuntr
Sounds like the chain is too tight
chico619
- Dec 20, 2013
dealer set chain 1/2 turn out the first time and second time 11/2 turns still makes noise they said drive it
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
You sure it is the chain case? These clutches whine fairly loud. Always sounded that way with a Yamaha.
Subaru2006
Subaru2006
Ehlett
- Feb 28, 2014
Mine does this too, anyone have any luck getting rid of it or is it normal?
stingray719
I would set the chain yourself. These have a spring loaded tensioner and "finger tight" to some might mean tightening into the spring and making it too tight, especially if you are adjusting it like a regular Yamaha. If in doubt grab secondary clutch and rock back and forth while adjusting. Too loose is much better than too tight, in my opinion.
Ehlett
- Feb 28, 2014
I'll have a look. I'll try loosening it off a little.
csederlund
- Oct 7, 2012
- Frederic, WI
- 2014 LTX SE
How many miles do you have since it started? Mine did this after my 1st service. It only lasted a little while. I'm assuming it stretched after they adjusted it.
Ehlett
- Feb 28, 2014
Good to know. 1100 miles now, I just picked it up so I'm not sure how long it's been doing it. I'm going to try loosening it off a little.
The vipers and 7000's seem to have a distinct whine type sound when slowing down compared to other motors in this chassis, even when the chain is adjusted correctly IMO. u have noticed it on these sleds in YouTube videos in addition to riding the sleds first hand. Maybe it's just this motor but I was thinking our Vector sounded similar. I don't think it's just the clutches when the cat version does it with cat clutches.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
I have 2 Vipers one LTX and one LTX SE one is very quiet the other makes all sorts of noise, both run great.
I've discussed with the dealer and they can't find anything wrong with either sled. I've got the extended warranty on both, I'm just going to ride them till I get a new noise or something breaks.
Funny thing is as they get more miles they both seem to be getting quieter clutch and chaincase side.
Ehlett
- Feb 28, 2014
I loosened off the tensioner and the whine is gone. It was about 1/4 and I loosened off to about 1/2-3/4.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Don't want to skip a cog on the gear though...once you do that its soon to fail
stingray719
**sj** said:Don't want to skip a cog on the gear though...once you do that its soon to fail
Viper has an adjuster that is spring loaded, some dealers are tightening it past the spring load and making them too tight. You have to be extremely loose to skip a cog, but like I said rock the secondary clutch back and forth and check for play just to be sure.
