Hotfingers
I got an M-12 with the universal mounting kit. I got everything installed by following the M-10 instruction booklet with the M-12 supplemental sheets, but something does not seem right.
So the question is, is the track is very tight, way tighter than it should be. I have the axle adjustment bolts pulled all the way out, and the track is still very tight. Has anyone here installed an M-12 on a RX-1 before and the same problem? Not sure if I got the right mounting kit for the RX-1 either.
Thanks.
-Hotfingers
Thanks.
-Hotfingers
