M10 mounting kit
burlyviper
Ottawa Lake MI
2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I am transfering my M10 from my Viper to a 03 RX1. Can I reuse my mounting plates or are the RX1 mounting plates different?
there is an install in the tech section. You do not use side plates of those stupid front side arms. You use a front and rear shaft, front shaft is notched for the stock front hole and the rear shaft will bolt to the stock location after the stock drop down brackets are moved a little forward.
Thanks for the info.
Finally got around to installing. The front was no problem once I made the spacers. Had an issue with the back though. The shaft on the M10 was too wide. So, I flipped the brackets and ran into a clearance issue with the track. Then I looked at the instructions from the TY Tech Section, the picture shows a shorter spacer outside of the idler wheel on thie back shaft. Am I missing something? Otherwise, I'll just make a plate myself. Thanks.
