apexg88
Has anyone tried to fabricate your own mod airbox. the one fix powersports puts out just takes the top part of the airbox, cuts two triangles in it and puts a metal screen than a fabric over it.
Im thinking about doing this myself
Any advice?
Any advice?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Be very careful with modifying your airbox yourself. If you do not know what you are doing you can easily loose power rather than gain anything but noise.
Welcome to TY! Please add your location to your profile.
apexg88
When doing it myself what should i avoid that could cause loss of power
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Perhaps Mike Knapp can reply with his experience pertaining to airbox mods. He is very knowledgable and well respected on this site.
I seem to recall that he did extensive testing which resulted in him putting his airbox back to stock because of the inconsistant power gains and gas mileage losses caused by airbox mods.
Yamaha Man
rockerdan....search for him for airbox mod. What he did was cut the "ribs" on top of the box out with a dremel and put SLP filter paper over it!! Thats exactly what I did, love it and love the cool sound that came with it!! I ordered a Hauck Fuel Accelerator though, because along with my gutted exhaust its running too lean on low end and I experience hesitation at low end accleration now.
Try searching this site and reading up on this before you start cutting up your airbox. Are you doing this on an efi or carbs? You posted on the Attak General Talk but that doesn't always mean that's what your doing this on. If carbs check this post out,,,
http://www.ty4stroke.com/viewtopic.php?t=66867
It's worth the reading, if your doing this on an efi, then you may need a fuel controller to adjust your efi.
yamahahaapex
Bought a mod kit off ebay similar to all the ones that are out. Awesome sound and no decreased power. I have two lids and tried them. I want to say I can feel it but in reality what maybe an extra 5hp if that. Hard to feel that. But if you look at it in concept. Extra air needs extra fuel and just like Yamaha Man the fuel accel is a must
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Your going to get alot of varied info. But here's what I found thru testing. Take it for what its worth.
http://www.ty4stroke.com/viewtopic.php?t=51898
Wisconsin
I opened up the bottom/front of the airbox where the stock air comes into the box. All incoming air is still filtered by the foam. No buildup of snow inside. I also removed the black plastic piece in the nose of the sled that is held on by one screw. I don't ride in deep powder. If I did, I'd replace that black plastic panel to keep the snow out of the engine compartment. No hesitation, no loss of fuel mpg. My dad has a stock 2006 apex er to compare to.
