Manometer - in Canada Where?
doo_man
Saskatoon, SK Canada
Getting ready to install ECP kit this weekend and want to synch carbs, has anybody bought a manometer in Canada? Where?
you can make one out of clear tubing ,yard stick & colored water Its call a water manometer they all so have mercery manometers have you eveer seen a manometer
Just on the net, had considered "home made" - just worried about accuracy. I know some guys don't even sych carbs, I just want it right the first time!
it will close enough or better then nothing at all, only fill the manometer 1/4 full to start with , you don't want to suck the water in the motor ,when the water is level on both sides of the tube thats zero ( thats with no pressure or vaccum on it )
send it down to regina so i can do mine.when i started it after the filters it was only running on 2 cylinders. 2 carbs were open more than the other 2, it sounded horrible. seemed good before the change though.oh well, i know the carbs are really clean now. they beenapart 3 times lol.i found the problem by leaving the filters off and watching the fuel atomize at idle. notice 2 were taking in fuel and 2 were not takin in any.
I have made manometers, and they work great for 2 carbs, but if you want to do it right:
MORGAN CARBTUNE II - U.K.
I have one and it's a nice unit.
