marginal snow wheel kit
ottercreeks
NJ
i just picked up the marginal snow wheel kit and am wondering exactly where to mount it. if you have it installed where exactly did you put it and how effective is it??
thanks :yam:
I mounted mine 1" in front of the rubber bump stop on the inside of the rail because most of my wear was in the middle of the track. They only have 80 miles on them so its too soon to tell how they'll work out. To determine what my mounting options were, I disconnected the torsion springs and compressed the suspension all the way down. Mounting them on the outside of the rail would have interfered with the torsion springs
Brad.
It should be mounted where you notice the most wear. On mine the most wear was occuring ahead of the rear idlers so that's where I mounted one set. The other set I mounted behind the front outside idlers.
Hey rik
Did you use the existing holes in the rails to mount back your wheels? I might add another set if I still notice wear
Brad
I mounted mine on the outside of the rails just in front of the rear idlers. That was where all my wear was. After 3000 miles it cut the wear way down.
