placement of marginal snow wheel kit ?
kodak
newfoundland,canada
Hi I just picked the marginal snow wheel kit and am wondering where to put it in front on curve or somewhere in middle or get another kit and put both any one have any opinions
This is where i put mine.
Most of the wear is up at the front. It will wear down the fastest up in the front.
in your picture you put wheels on outside on another link i saw he used the wheel in side the rail also what do you think of putting two kits on and do you know how to adjust front suspension strap
i run 2 kits on mine. placement, inside or out, it's gonna help. take a look where you slides are wearing the most, & put them there if you only go with 1 kit.
adjusting the strap, just take that little bolt out & tighten as desired. the tighter you go, the less wear on the slides up front & more bite you'll get with the skiis.
I did all the Wheel kit and tightend the strap while the skid was out and apart so it was really easy to do. I would guess that if you used rachet straps to tighten up the front of the skid to loosen the strap it would make it a lot easyer.
I have seen the wheels on the inside and out I dont think it will make a big difference.
Make sure you use locktite. I herd that they tend to fly off. Especially the left side i think since the wheel turns in the loosen direction for the mounting bolt.
If you are only geting out kit i would say put it up front. I am not too sure if it really needs it anywhere else. I have not had an issue with the rest of the slides just the front.
or you can have someone sit on the sled while your adjusting the strap.
Lol that would be the easier way to go
