68Johnny5
Still a little fine tuning to go yet, but here is a video of how it runs so far. This was shot at 6300ft.
LINK>>>>> http://www.youtube.com/watch?v=8k6Y9jxF4K8
I removed the original muffler provided with the kit, and installed this 2lb muffler I found on eBay. It sounds good and works well.
12- pounds boost @12000rpm
Powder snow is plugging filter at times. Should improve with side shields.
Clutching is close, hits rev limiter if W.O.T. from stop. Adding shims to prmary to get engagement up to 5000.
Changed top gear to 18 tooth, 138km/hr(85m/hr)at rev-limiter. Still Picks skis of the ground at 100km/hr
teerex
Do you have a close up pic of the muffler please ?
rfabro
The USA distributor(Mark Leipheimer) told me not to use the side panels because they would trap too much heat. The rear cowling, with a skinny muffler, seems like the place to mount intake.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
MY MCX MTN LITE TURBO IS FOR SALE GLEN 705 645 2247 $9000 CANADIAN
summitking
sled
PMed you gsxr
PMed you gsxr
68Johnny5
Muffler Photos
Teerex,
I will take some more photos with the seat off and post them at my account at Photobucket.>> http://s172.photobucket.com/albums/w6/johnpiccolodotca/
Here are some photos of the muffler for you.
http://i172.photobucket.com/albums/w6/j ... _001-1.jpg
http://i172.photobucket.com/albums/w6/j ... 04_001.jpg
http://i172.photobucket.com/albums/w6/j ... 03_001.jpg
Cheers,
Johnny5
teerex said:Do you have a close up pic of the muffler please ?
Teerex,
Cheers,
Johnny5
teerex
That was some huge diameter, must be a bit noisy ?
68Johnny5
I ran with a sraight pipe, while I waited for the muffler to show up. I think the muffler is probably half as loud as the pipe...... you can hear it in the video I posted earlier.teerex said:That was some huge diameter, must be a bit noisy ?
Johnny5
teerex
How much more weight did you have to throw on the clutch compared to stock muffler ?
gsxr
- Feb 24, 2006
- 2023 SRX
running 68g now !
68Johnny5
Mc-Xpress turbo Mtn. Lite setup.
Teerex,
This is the setup I'm running:
Rollers-14.5mm (8cr-17624-00)
Weights-48.7g (8bu-17605-00-00)
Rivets-4.5g (90261-06033-00) 6 of them
Primary Spring- Pink Blue Pink (90501-606g9-00)
Primary Shims X 3
Yellow Secondary Spring-(90508-60015) and set to C2
18 tooth top gear
12-13psi Boost
11500-11700rpm
Hope this helps.
Johnny5
teerex said:How much more weight did you have to throw on the clutch compared to stock muffler ?
Teerex,
Primary Shims X 3
18 tooth top gear
12-13psi Boost
11500-11700rpm
Hope this helps.
Johnny5
teerex
Thanks... it could be some help. But I have the Super Tips weights and nothing else is done yet to the clutching. First thing is maybe to put some shims in there.
aksteepndeep
Johnny5
I am thinking you have the right muffler setup.
Did that have an application for that glasspack. I'de like something similar on mine. Thanks
68Johnny5
aksteepndeep said:Johnny5
I found the muffler on Ebay. Check out these ones below. Copy and paste the Item numbers into the search window on Ebay.
Item #270094511238 <<<***This is the one I bought***
#250089624562 <<<Similar, same length
#150096877486 <<< Similar as well
-Cut the MC muffler inlet pipe flush off at the flange.
-Cut the inlet pipe off the glass pack and have a muffler shop expand and weld a 2-1/2" long piece of 2" pipe to inlet.
-Mount the muffler where you want it and transfer the angle of the flange to the pipe and cut.
-Match mark, tack and check fit.
-If ok, weld to flange
**Do Not weld on sled, you'll kill the ECU
** I found a good muffler mount at Canadian Tire
Good luck
Johnny5
