fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
Hi Robbie I know you said before to call if I needed help. Would you give me a call when ever is good for you please. 902-499-4860 thanks grant
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
My 290 2011 xtx has been flawless 14700 km . No over heat at all ! But not from the start ! I had to port the waste gate and change the boost controll, I was overboosting by 7 lbs , could have broke the motor in 5 km if I did not have a gauge to see !! Eric at MCX sent me pieces quickly , awesome since !
You need gauges to check the set up ! I could have run since without gauges once set up properly !
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
The MCX display is expensive if I remember correctly. Would have gone that route if I could have made fuel changes from it. There were some problems discussed on this site with the koso unit, I think MrSled had issue's?
gsxr
- Feb 24, 2006
- 2023 SRX
The MCX fuel controller is excellent, no tuning needed , as long as boost and the fuel system are correct !
MY 290 has gone 228 km pump to pump running approx 30% of ( the 228 km ) hard !
kviper
- Nov 7, 2003
- Oakfield WI
Yes but don't bank on it till it's verified by gauges!
gsxr
- Feb 24, 2006
- 2023 SRX
You need gauges to check the set up ! I could have run since without gauges once set up properly!
As said above , I would have broken it for sure , without checking !
fast n furious
- Jan 24, 2010
- Nova Scotia
Really I just ordered it. Let's hope notThe MCX display is expensive if I remember correctly. Would have gone that route if I could have made fuel changes from it. There were some problems discussed on this site with the koso unit, I think MrSled had issue's?
kviper
- Nov 7, 2003
- Oakfield WI
Maybe check with Tom to see if it was an isolated case.
fast n furious
- Jan 24, 2010
- Nova Scotia
just ran it up on stand and can watch it push fluid every crack of throttle, damn tear down time. wont be ridden again without gauges!!!! should be included with every kit, this sucks.
kviper
- Nov 7, 2003
- Oakfield WI
Sorry to hear that! Good luck!
