measurement needed my sled is out of town.
new4stroker
P.A. Saskatchewan
I need a new ramp for loading my trailer. There is a good deal on a used trifold in town but it is only 48 inches wide. Will the 2011 rs venture fit up a 48 inch ramp?
If anyone can give me the ski measurement from outside edge to outside edge that would be awesome. thanks guys,
outside to outside should be exactly 48". You will be fine using a 48" ramp, however it would be a good idea to put some kind of rail on each side so the skis won't go off the sides.
If it's like the one I have, the aluminum rungs will be destroyed by your carbides. You'll need 1/4 or 3/8 plywood or some kind of plastic where the ski's slide. I used mine 2 seasons after someone borrowed my trailer and brought it back minus the ramp. It's a cheaper alternative and will work, just not as trustworthy as a regular ramp.
Thanks Guys. Hope I can get a hold of the guy now and pick it up. I do have some puck board that I plan on adding where the skis go to save the aluminum.
