Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Has anyone mounted the windshield to aftermarket risers like the PowerMadd ones? I would like to replace the stock one with the PowerMadd universal pivot riser system. I assume I just need to drill the mounting holes in the riser and I'm good to go.
http://www.powermadd.com/products/unive ... ystem.html
71rdrnr
- Oct 12, 2009
- Winnipeg MB. Canada
- 2010 phazer RTX
I milled out a block and mounted it below the factory riser and made up longer bolts since no one makes the length needed, I even talked directly with ARP and nothing. My wind screen is also 3" higher and still mounted in the factory riser.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
We (Muffin Works) have riser kits for the Phazer that will accomodate the mounting of the windshield and the speedometer.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I'm in the process of having a block that slips under the stock riser custom made. It won't be angle adjustable but since the stock riser is nearly vertical and I'm only going up 2 inches it won't move the bars back too far.
I drilled and taped the stock riser two inch lower so the windshield will be in the same place.
When I get a price for the block I could let you know if you like.
Andrew
Andrew
Cubby
- Dec 14, 2009
Thanks Andrew.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Hi Cubby,
Just a a follow up, it was fairly cost prohibitive to have one made as a one off. I think I'm going to get a Lake Effect's one. That way I can keep my windshield by still get at 2.5 inch rise.
