viperhauck
Have install a mpi kit ion my apex this weekend. Almost done but some few ??
On the blower oiltank next to the oil cap its a small "vent intake" or something. I dident find any instructions what I should have there.
And on the IAC its a hose that going in to the oem airbox. What should i do with that hose now?
SRXSRULE
there is a small dia hose that comes off the vent fitting on the oil tank. I loop in back down through one of the hoses in the oil tank mounting brackets.
The hose off the IAC, turn it so it points down. nothing goes on the end of it. Eric
viperhauck
So the small hose is just a vent to the oiltank? Its not supposed to go somewhere?
shawnmcgr
viperhauck said:So the small hose is just a vent to the oiltank? Its not supposed to go somewhere?
Yup, just a vent. I ran a line into an "overflow bottle". I prefer the overflow bottle so I can see what has overflowed and how much. Some run it into chassi tubing by drilling small holes, if I remember right. Just make sure the vent line ends below your tank or you could loose charger oil when you flip it up side down.
If I remember right I tied the IAC vent line into my crank case vent line which is routed to up above my engine.
