hornydevil
Had a good time riding a 180 MPI Turbo Nytro last weekend in some really deep powder. Verry impressive and crisp throttle respond and no turbo lag what so ever, going down hill carving and boon docking or climbing and side hilling the turbo perform very well even in the trees it works awesome. It perform well enough to turn the 174 CE track. MPI build a very nice set up with this kit, watch my friend install it on his Nytro with no modification to the headers, just a clean and bolt on set up ( just the one hole for the charge tube thats all).
LuckydawgAK
LuckydawgAK
I found both Turbo and Super kits on Yamaha's website but only the Supercharger on MPI's. Are Mpi Turbo's only available through Yamaha?
shadow44
Same here, looked on their website and can't find anything about there turbo stuff
hornydevil
shaddow44 said:Same here, looked on their website and can't find anything about there turbo stuff
Not sure who would be the dealer in Ontario. Give Darren @ E&S Motorcycles in Fort Saskatchewan Alberta it is the MPI distributor in Canada and he actuly help with the R&D of this turbo, I do believe that there is an upgrade kit coming out rite shortly for the 180 kit that will be able to produce 220/240 (10 to 12lbs of boost) if I'm not mistaking .... I had a chance to ride the upgrade kit and it works flawless... realy nice system and clean set up.
hornydevil
LuckydawgAK said:I found both Turbo and Super kits on Yamaha's website but only the Supercharger on MPI's. Are Mpi Turbo's only available through Yamaha?
Not to sure who you should contact in Alaska, I will try to find out. My guess would be your Yamaha dealer in you're area or MPI themselve. The 180 kit run 7 to 8 lbs, no welding or cuting of the exhaust as to be done on these kit, I will try to get more info for you.
HYFLYR
Anchorage yamaha is a mpi distributor, we can get you fixed up if you would like. Built one mpi turbo this year and many, many supers from them. To be honest I prefer their turbos over the supers.
Lashcat
Northern Power Sports is a dealer also in Fairbanks. Phillips Recreation maybe one too.
I bought mine direct.
hornydevil
Here is the link for the distributor in Canada, www.esmotorcycles.com and here is one of the link that give you some info, http://www.snowandmud.com/forum/f447/ne ... 40530.html
