Mtn tamer suspension
boostedphaze
Dell Rapids,SD
how well does it work? does it get you on top of the snow? and is it worth the money? curious to here some feed back before i buy it. I have an 07 phazer mtn with a supercharger and am putting a 151 on soon. THANKS
works great, its alot lighter and rides much better. The down falls are the limiter strap they send you are junk, you can run a stock nytro limiter
strap and they seem to hold up better. If you can run two straps that would be even better,{ I think timbersled has a update for running two straps now}. the bushings in the rear arms will fall out if there not greased regularly, {again this has been changed with a differnet bushing material}, I havent tried my skid with the updates yet to see if they hold up. My phazer has a turbo and a 153 so it gets up on the snow very good.
Yes the Mountain Tamer will make your Phazer climb. My buddies out climbs a stock Phazer.
Get the 2010 suspension. All updates are installed. Allen is a class act.
I can't wait till mine gets here for my RX
I havent installed my Sons yet on his phazer but it came with 2 limiter straps so I think problem solved.
FYI ~ I have a timbersled skid on my TAPEX and the limiter strap lasted 800 miles boosted before it broke. 1 phone call and they sent me the upgrade FREE. Excellent customer service and quality products that make a difference. :Rockon:
