spray25
RX1MPete said:I guess no one knows where to get pre-filter material. You know the stuff is like nylon, fine fine mesh and no snow will stick to it. My friend's Poo has it on his intakes and snow just falls off (never sticks). There is no restriction in air flow either. I figure if you put some of that on your intake (along with putting something on your vents) it would take care of the problem. The snow would have to get pretty deep in your belly pan to plug up the intake with a pre-filter. Is anyone familiar with the stuff?
SLP sells it.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I'm on it!
spray25
Hey excellent idea I will have to buy some and put it on.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Exactly what I found Spray. My plan will be to order it, cut it with scissors and use a thick kick-#*$&@ elastic to hold it in place on the intake of the air box. There is less than 1% air restriction with this stuff. I will still use nylons cover the vents, but I believe the root of the problem is the intake itself. It is pretty hard to cut off all the snow going in, but the pre-filter intake mod should imho.
