Need a new track ..How big can i go ?
Nytro Nork
Saint John NB
I have to replace the track on my Nytro this summer and i was wondering just how big i can go paddel wise ? Its a 2009 Nytro fx 121''. The tunnel protectors are still inplace and i dont really want to remove them as i plan on re-studding the new track .
With stock drivers (9tooth) i think 1.5" is the biggest you can go and still keep the tunnel protectors..
I removed both tunnel and heat exchanger protectors when i installed my 1.75" track..
Do a search in the FX Nytro section, and you will find a lot info regarding this..
Good luck ;)!
Good luck ;)!
X2 and it helps with ice.
I think the oft kit is one of the best extension kits out there. They make really good products and have a great customer service.
Im running a tracksusa 144 kit on my RTX and am really happy with it,
but the only reason i went with tracksusa instead of oft is cause i got a package deal on rail/ tunnell extensions and a new track at the time i extended mine. Since the shipping cost overseas is quite expensive i went for the whole deal instead of ordering the parts from different companies. Otherwise i would have gone OFT, no doubt about that.
Good luck on your decision ;)!
Hey nork..... I've seen you out on the trails with that nytro of yours... as stated above, go with the 1.5 track, we did a crossover 1.5 on my buddies XTX, and made the sled a completely deferent beast in the "loose" snow... I'd go with the 136 extension....if not longer.. i just finished a 151" tunnle extension and a 144 rails from Hartman for my 40th.... awesome kit. comes with new bumper and all. I do wish the rail extensions were cut for the hyfax, mine are not, but i should have ordered....
