Boston RX1
I just registered my sled and the registration stickers will not stick to save my life. I cleaned the old stickers off and made sure the surface was clean and dry. They worked good the last two years. Maybe I just got some bum adhesive on the stickers. Any suggestions?
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
How about contact cement? You can even get it in a spray, or you can use invisible tape and go over them!
BIG BLACK WARRIOR
Dana, If you remember my Warrior from last year, I had the same problem. What I did was get 2 thin pieces of plexi-glass, cut to the same size of your registration. Drill a hole in each corner (very carefully or you will split the plexi-glass). you can then counter sink each of those holes,and go get 4 small brass bolts that will fit your drilled holes. Put these on your belly pan, the sticker sill stick to the plex-glass. This is a permenant, so make sure you want to do it this way before you drill 4 holes in each side of your belly pan. It does look nice thoigh.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
They don't stick real good when its cold take a hair dryer and warm up the surface first and the sticker
NH Stickers suck. They have had a adhesive issue for the last two years.
stinx
return them and get some that will saty in place
- 6K
