The Snow D.O.
WD-40
Works like a charm!!!!!
Superman
- Jan 21, 2005
- Gaylord MI
- www.lakeffectsnow.com
A heat gun and goo gone here.
SledFreak
- Feb 7, 2005
- Ontario. Canada
cire said:So your heating the underside and how warm are you getting it? Thanks
Well, it's hard to say... It's only a hair dryer, but I get it good and warm from underneath, then switch to the top side and they peel right off.
Interesting I will try that ~ thanks
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Charcoal lighter fluid. Wipe .....adhesive gone no damage to hood at all. Also spray starter fluid works well. I like using what is in the tool crib. Goo Gone works well with some rubbing but never seem to have handy. Always doing this in below freezing temps.
the weasel
3M adhesive and wax remover. You can buy it at Wal-Mart. I've used it on painted surfaces and plastic windshields. It removes adhesive with very little rubbing and does not harm plastic surfaces.
CaptCaper
- Jan 1, 2007
- Northern N.H.
I tried all of the above but these new (last years) NH regristation stickers won't come off. I tried heat and then I go to peel and it won't peel. You can catch it with your fingernail but only about 1/16 or 1/8 in. comes. The previous years came right off by heat and peel whole sticker off.
No dice with these. I'm not talking about the adhevise left. That I can do with these. It's the material of the sticker itself. I think it's reflective somewhat. Crap.. anything stronger to soften them and it'll melt the plastic.
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
I have tried many different ways to remove stickers some come easy with a heat gun and somemore you need a plastic scraper alright on the tunnel but be very careful using it on the hood. I found goo gone to work very well but a bit of gasoline on a rag will work just as good.
