Groomerdriver
I'm just about to pressure test the coolant system on my 05 Vector and can't find the specs anywhere.
Did a search and found (on a Nytro I think) 14 psi for 30 min.
Does this sound right for my Vector?
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
look at the cap. if i is a 15 lb cap the system should hold 13 to 14 lbs for 15 to 20 minutes
service manual say 14 o 18 psi for 10 seconds
Groomerdriver
maxdlx said:look at the cap. if i is a 15 lb cap the system should hold 13 to 14 lbs for 15 to 20 minutes
there are no markings on the stock from the factory cap!
Groomerdriver
It held 10 psi for 30 min. Close enough.
