Nytro coolant loss
Nick454
Age
37
Michigan
12 nytro xtx
Calling all Yamaha gurus, I have a 12 nytro with an mpi blower. The problem I'm having is coolant loss. Pressure tested the coolant system to 20 psi for 24hrs no loss. Ive done a cylinder leak down test with no issues found. Oil is clean ,no leaks , and no smoke. Any input would be greatly appreciated!
Age
51
Dublin Ontario
Canada
2019 Sidewinder LTX
Most likely head gasket. You're just not building enough pressure with the those tests.
Put the coolant over flow hose into a catch can the next time you ride it.
Srxspec
Ulmer Racing
TY Advertiser
Tech Advisor
Menno, SD
Website
www.ulmerracing.com
2014 Yamaha SR Viper LTX, 2014 Yamaha SR Viper RTX SE, 2015 Yamaha SR Viper MTX SE 162 (turbo), 2015 Yamaha SR Viper MTX SE 153
LOCATION
Menno, SD
WEBSITE
www.ulmerracing.com
Put your coolant pressure tester on the system at 20 psi. Put your leak down cylinder on each cylinder, but make sure it is pressurizing with 100 psi minimum into cylinder, if it is a head gasket it will likely make the coolant system pressure go up if you use the leak down tester to pressurize the cylinders at the same time as the coolant pressure tester is on as well.
BADSLED
Syracuse, NY
2012 Nytro MC Xpress 270
2021 Sidewinder LTX SE
Are you loosing coolant in overflow can only or the entire cooling system?
Mooseman
Greely, Ontario
Canada
'07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
LOCATION
Greely, ON Canada
If it's puking out the overflow tank, It's likely the head gasket. Had the same problem on my GT. It was fine if driven easy but as soon as I went WOT, the pressure would make the coolant puke out. Didn't burn it or go into the oil neither.
BADSLED
Syracuse, NY
Nick454
Age
37
Michigan
12 nytro xtx
I fill the radiator and the overflow, after about 75 miles the overflow is empty and the radiator is going down.
Nick454
Age
37
Michigan
12 nytro xtx
Not puking out of the overflow , it's emptying it.
Mooseman
Greely, Ontario
Canada
LOCATION
Greely, ON Canada
Any milkshake in the oil or the exhaust smell like coolant?
Nick454
Age
37
Michigan
12 nytro xtx
Nope, I've rode the sled twice, the first trip it started overheating about half way through the day. Hauled it back to camp to fined it low on coolant. The second trip brought coolant with me and had to fill the overflow after 75 miles
Mooseman
Greely, Ontario
Canada
LOCATION
Greely, ON Canada
Put the hose that comes out of the overflow into another bottle to see if it comes out that way. If it does, it's the head gasket. Try when running it easy and check. Try again running it hard and check. Mine only puked coolant when run hard.
Is it overheating as a result of the low coolant or something else? How's the thermostat?
Nick454
Age
37
Michigan
12 nytro xtx
Low coolant, if I keep it full it's fine, no overheating problems.
Mooseman
Greely, Ontario
Canada
LOCATION
Greely, ON Canada
Have you tested the thermostat in boiling water?
Nick454
Age
37
Michigan
12 nytro xtx
No, if I keep the coolant full no issues. The only reason it overheated because coolant went low. The temp light was going on and off so it wasn't getting to hot .
Mooseman
Greely, Ontario
Canada
LOCATION
Greely, ON Canada
Try this ↑
