Yamahnator
Ok, so I put some riser on. 2 inch sportech risers. Get everything set and fire it up. I immediately see the check engine light flashing when I turn the key, also the odometer and the rpms flash back and forth. Fire it up, gets started and idles ok.
Try the flipper and it stutters and stutters and then all of a sudden goes (putting a small dent in my garage door bottom panel which was only 2 inch away, thankfully I was wondering if it might do that and had hit the kill switch as soon as it moved).
This is the TORS I'm assuming. How do I fix this? Seems to be plenty of room for the throttle cable, but I must have hit something or pulled it out of whack? Supposed to go riding tomorro!
Phazed-Coug
If you didn't reroute the throttle cable , you may need to, just drop it under the bar, instead of over the bar. you can do it from the bars, couple phillips screws, on the throttle assembly.
Yamahnator
Phazed-Coug said:If you didn't reroute the throttle cable , you may need to, just drop it under the bar, instead of over the bar. you can do it from the bars, couple phillips screws, on the throttle assembly.
I did that, no difference. It's not a matter of the cable being tight I don't believe. Maybe I pulled it too hard or something when I was adjusting one of the cables and it's out of whack. It has plenty of room.
TIMSMXZ
my light did the samething, i just pushed on the cable were it goes into the plastic housing and it went away. theres a metal clip that goes on to the cable in side of the plastic housing, maybe that has something to do with it??
