Need help choosing?
cat hunter
Irish Quebecer, Canada
I have a 2006 Apex GT and live in the Ottawa Valley on the Quebec side.I need to know the best dealers with experience on how to install,knowledge etc on the best choices and selection of NOS.I don't want something you have to mess with regularly, need something virtually maintenance fee without causing damage or loosing reliability.Looking for 30/40 hp increase without having to do major clutching if possible.Any info will be appreciated.Thanks in advance. :4STroke:
I rode a sled last year with a Boss Noss and I wasn't that impressed. Boondockers is similar. You'll be lucky to get 25HP out of it. I have a NOS kit that I got from Summit Racing. It is a way more difficult install but you get a full 58 HP at the crank with the 40HP jetting. Also the Boondockers and Boss Noss are dry kits which means that you have to tune them with a Control Box. My buddie finally got his to work after riding it all last season. If you want ultimate performance then I would use NOS or Nitrous Express. With my NOS kit, when I use it, it's like turning on a light switch its that good. But the install is pretty technical only use these if you are capable. You will need to add more weight in the clutch for the spray. CB Performance is using NX you may want to give them a call.
i dissagree. i have a 60 hp boss noss and it dynoed just beetween the 50 and 60 hp increase. 03 rx1 185 hp juiced. i have heard boondocs kit is low
