Need help from the guys with Mountain Tamer skids.
niko said:
what you weigh? front shock amount?
230 ish with gear. From what I can remember I had 150 in the rear(skid in the top drop bracket hole) ,90 in the front skid shock, limiters all the way out, 90 in the front suspension, sway bar disconnected. From a dead stop it pulls the skis 2-3 inches out of the snow, more if you lean back, less if if you lean forward, VERY controllable. On the trail, if you sit close to the tank you can tokyo drift around the corners. This is with a powerclaw track, so it hooks up good.
I am really interested in maybe purchasing the Timbersled skid for my boosted Apex but am a little concerned with durability.I have heard rumors that it isn't tough enough for a boosted Apex.
From the other skids I have looked at,eg.Racers Edge,CR Racing M10 it seems like a affordable solution for ski lift,I don't want it coming over backwards while climbing but at the same time don't want to be replacing parts in the middle of the season.
Please post your experiances with the TS skid under boost...
Thanks in advance,
smokindave
