Need help installing M7 susp in Ekholm tunnel!
disco
Deer River Mn
Website
grandgarages.com
I am buying a 141 susp, and putting a 151 track on into my Viper chassised ekholm tunnel. I have never done a non yamaha susp, and need to know what to do. Need any and all info, center to center for the front and rear mount hole and anything else.
I appreciate any info that will be given here!
Dan :yam:
Never done that tunnel, but I just did my RX-1 with an M7 and it's pretty easy. IF you can mount in the front holes like the RX-1's it's just a matter of making new rear brackets out of aluminum and I believe the distance is 31 3/4". I actually measured the holes distance on the skid with a wooden $1 yardstick and drilled holes in it at the 1" and at the 32 3/4" lines, bolted the front hole up and used the back hole as a gauge to make a cardboard template. From there you make your rear bracket out of 1/4" aluminum and mount it. On the RX-1 you have to make spacers for the front mounts. Not sure about your tunnel. You will have to measure the width of it and go from there. Let me know if I can help you any more. Good luck!
Aaron
where do i find ekholm products
someone pls give me the website for ekholm part
