Need Help Suspension 06 Apex ER
colind
I have a 06 apex , I put Ohlins front shocks and usi trip skis w\ shaper bars , limiter strap is full tight. Very heavy steering . What do i need to do to lighten up the front end? I am 5'4" this is not fun for me!!
Set your limiter strap mid point and your transfer rod mid also as a starting point you will/should take a lot of pressure off your skis and see if its what you want, I wouldn't fool around with the limiter strap once set to mid, I prefer adjusting the transfer rod I find it more effective and easier to fine tune also check your SAG on your rear MONO shock to be within your weight spec it should be between 40 to 45mm.
