VectorLTX2012
I've tried to turn my headlights on by holding thumb switch in the down position and turn the key to on position and waiting 8-10 sec for the lights to come on. Nothing happens, I mean the headlights don't come on.
I tried several different times using different intervals and lights don't come on.
This is a 2012 Vector LTX, so I'm not sure if that trick works on the new model year.
Can anyone help?
Chester
This is a 2012 Vector LTX, so I'm not sure if that trick works on the new model year.Can anyone help?
Chester
nards444
fuses, light bulb. I know older sleds some of the didnt turn on or were real dim until they go tup in running but most newer sleds arent like that. Check all the connections.
NY AttakGT
With the sled running? or just turning the ignition switch on?
Super Sled
- Feb 25, 2009
- Summit X
I've never heard of this trick. I guess i'll try it tonight when I'm home. I'va always thought the sled has to be running.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Hold thumbwarmer switch down. Lift kill switch up. Turn key on. In a few seconds all lights including the dash lights will come on and no motor running. Nice feature.
NY AttakGT
Vectornut said:Hold thumbwarmer switch down. Lift kill switch up. Turn key on. In a few seconds all lights including the dash lights will come on and no motor running. Nice feature.
Nice. Is that just on the '12 Models?
nealchick
- Jan 14, 2009
- Long Island, NY
- www.briarclifflandscape.com
Just tried it on my '10 Vector, no go.
N---
N---
VectorLTX2012
Thanks, the only thing I wasn't doing was the kill switch part. I will need to try this now!
Chester
VectorLTX2012
I just got back in from trying to turn my headlights on without starting the sled as you described, the head lights did not come on, but my dash lights did.
What year is your sled?
Chester
pat the rat
- Mar 13, 2006
my o9 works,i think its only the carb models,from 05 to 09
VectorLTX2012
pat the rat said:my o9 works,i think its only the carb models,from 05 to 09
I'm thinking the same thing. If people are getting the headlights to come on without starting the sled please post your sled model and year.
thanks
Chester
Super Sled
- Feb 25, 2009
- Summit X
I tried it on my 2010 Apex MTX just a bit ago, the guage cluster lit up and came on but no headlights. And I don't have HID's in that sled, so that's not it. I bet HID's won't light up either on others.
dylanjen9
Headlight and gauges came on with wifes 07 vector
mbw919
It works on my '06. Perhaps Yamaha changed it on the newer models.
pat the rat
- Mar 13, 2006
its an efi thing,my phazer headlights dont come on but the pod does
