Need help with Attak coolant refill?
attakmod
Labrador
Whent out today and drained my coolant and put the rear up with the drain screw out put in the anti-freeze until it came out the hole then put the screw back in. I used 2 1/2 L of anti-freeze and 1 1/2 of water. I went for a ride and the fan and temp light came on and the rear cooler was cold. Can anyone tell me whats going on? :o|
air lock. raise the front of sled( snowbank) remove rad cap and idle sled. air will bleed out and add coolant to tank to fill.
How high does the sled have to be? Just hogher than the rear exchanger? I don't have the stock deal anymore. Running a u cooler. No bleed off...
I take my forklift and raise the front about 2 to 3 feet. Works well.
