Duane bearfield
- Dec 16, 2016
- Templeton pa
- 2004 rx warrior
Hello I have a 2004 rx worrior. it won't start when it's cold out. unless you put gas in the carbs though the air box. when it's warm it starts rite up anyone know what's wrong. thanks
Al Bundy
- Mar 4, 2016
- Maine
- 2004 Rx Warrior
I will tell you the previous owner of my Warrior had the valves adjusted because he was having similar symptoms. He had about 10k on it. Of course it'd be good to ensure the carbs are clean and the coils are working properly 1st.
Indy
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
You are giving it full choke I assume.
also 0w30 oil helps it spin fast enough witch is a problem around here at -40. learned that one the hard way.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
If it's been siting gas will flow back to tank, but shouldn't happen with daily usage.
Duane bearfield
- Dec 16, 2016
- Templeton pa
- 2004 rx warrior
YesYou are giving it full choke I assume.
Duane bearfield
- Dec 16, 2016
- Templeton pa
- 2004 rx warrior
Already clean I clean them before I even run it at the beginning of every season
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Try pressurizing the fuel tank by blowing air into the vent tube (clutch side) and holding your thumb on it before cranking. If it starts quicker that way then you know that fuel is not getting to the carbs quick enough and you can start eliminating things from there.
