mopar nut
hello i have a 2004 RX Warrior and when i start it (sometimes) the low beams don't work but the high beams do? and some times they both work?
so what do u guys think it could be i don't think it could be a lose wire cause the high beams always work so any help would be great. thanks guys!
80h4thephaze
Maybe check the wires to the headlight... Maybe that might be the problem. My family's bravo had a loose headlight wire and the lights used to go at night every once and a while. So I was riding in pitch black. I managed though. So ya maybe check the wire.
Len Todd
Do the lights work after toggling the switch several times? If not, it is most-likely is the Headlight Relay. When the lights do not come on, with the switch in the low beam position, try tapping the relay. If this does not work to turn the low beam on, then you may want to look for voltage on light green wire coming off the switch when the low beam is switched on. When the low beam is on, this voltage energizes the headlight relay to turn on the low beam's power and shut off the high beam's power. The headlight relay should be the middle relay.
mopar nut
ok ill try that. thanks guys for all the help
