nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I'm getting ready to install the skid from my XTX into my '06 Apex, and am looking to find information on where to locate the skid in the tunnel. I'm sure I could figure it out on my own, but I'd like to ask for a few pointers!!
Should I just measure from the center of the driveshaft on the XTX and transfer those to the Apex, or should I make changes for the different 'rakes' of the 2 machines?
Thanks for any info!
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
What are you putting in the xtx. Paul
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
He's parting it out; hit a buried fence postmaxdlx said:What are you putting in the xtx. Paul
nate007
- Dec 25, 2006
- Iowa City, Iowa
Yeah, I hit one fo those 't" shaped fence posts burried in the drifted snow between Solon and Sutliff, Paul. It went through the bottom cover, put a small dent/hole in the oil pan, and ruined the cooler. I could replace the pan and cooler and it would be fine, but the deal didn't turn out too bad this way.
My dealer (IC Motorsports) was real good about getting the estimate up there enough to total it since I flipped it end over end twice, but since I had a large claim on it, I may have trouble getting full coverage insurance on it again. I was able to buy this one out, and have enough left to get another one from Port.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Man that sucks. Hope you faired better than the sled. Paul
nate007
- Dec 25, 2006
- Iowa City, Iowa
Sled really isn't bad. Just had a good, thorough estimate from ICM. Needs an oil pan, a heat exchanger, belly cover and it would be fine. They not picked the estimate enough to get it totalled for me, but it really didn't need to be.
welterracer
Nate hows that apex coming along..
nate007
- Dec 25, 2006
- Iowa City, Iowa
Its all back together and running, just trying to find the time to get the panels painted, and thinking about swapping the skid from the XTX. (Which I will need you to powdercoat to match everything else!!) Can you do it if I bring it by Monday? Pm me or call me if you still have my #.
nate, try pm'ing ding as he has an xtx skid in his viper. he might have some hints for you. he is the only other member i am aware of that has done the swap into another sled.
nate007
- Dec 25, 2006
- Iowa City, Iowa
I think I 've got it figured out. I'm going to use a plexiglass template with reference points for each sled from the driveshaft back, and transfer the factory locations from the XTX to the Apex. The only variable will be the depth of the tunnel, and the "attitude" that I want.
welterracer
Nate when do you need it done by? I do have a few other things going, but nothing too pressing..
cr8zybaby
- Dec 21, 2017
- 2007 attak gt
cr8zybaby
- Dec 21, 2017
- 2007 attak gt
I am trying to put a 2018
Thundercat 137 in my 07 attack GT. Any numbers you could give me would be awesome. I am like 50 miles away from any dealership and I've been posting everywhere trying to get help
TIA
TIA
