Need some Drag N Fly help.
apexer said:
Ran my sled today with same setup. You are getting same results as me. Pulls hard to 75-80 then flattens off like you said. I am also creeping to 9100. I didn't get any top end runs conditions weren't great, what are you seeing for top end speed.
I didn't have really good hard pack conditions because people are just starting to run the river around here so there is a fair amount of loose snow on it yet but I saw 93 mph on the speedo max. I think my brothers completely stock sled may have been 1 or 2 more than that. I would be extremely happy if I could get it to pull hard to 90-95 and then creep to 100 or so. I think I will try adding weight to the overdrive spot and see what that does.
Turk what do you suggest to get the rpms down a little. Also do you have any experience with Supertorquers roller secondary, I had a friend put one on an 03 Rev 600 and had great results pulled harder and lots of topend, problem was RER reverse wouldn't work.
You can add another washer to inner but your gonna have tp grind down the bolt a little to clear the spider..or find a strate 47 helix & run that.
I have No experience with that supertorquer roller.
