dieselmatt1
just finished installing turbo and gears last is clutch kit, im not to sure of the yamaha clutch like i was with the ski doo,
am i going to need any clutch tools ?
any tips i should know?
what rpm am i going to look for at 8psi of boost?
anything will help thanks
LJ 452
I would go in to the turbo section, I'm sure you could find what you're looking for there. As for the clutch tools, really shouldn't need anything. Just hold the cover on while removing the six bolts and you'll have clear acess to the weights and spider. Just be careful and don't loose the little nylon bushings between the weights. RPM's I have no clue but would assume that you would want to maintain stock as the clutch can't handle much more anyway. Like I said, visit the turbo section and search away, I know your not the first to turbo the Nytro.
