kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Wondering what the general principles are on suspension design in relation to the rear suspension position in the tunnel compared to the front suspension.
For my specific example I would like to mount my ZX2 rear suspension 2-3" lower then it is now for installing a larger lug track and riding in deep powder only out west. When back on the trail I would relocate back to proper positon.
I tired this long ago with a edge suspension and leaving the front bolt in the right position and raising the rear end to give me more clearance in the back end but it ended up (at the advice of ahicks) coupling the suspension just sitting there and it would go down and not come back up after a bump. So I learned from that, the mount points would have to be lowered at the same proportions. What else will I screw up by doing this?
I would really like to have a sled I can convert from a 162 to a 121 back and forth with no coolant mods so I would like to lower the suspension enough to clear my rear heat exchanger with a 2.25" lug track. I am alos going to leave my stud protectors in and notch the track, I'll swap drivers to ge the right clearance there so I'm basically trying to figure out the suspension 'depth' I know it would look wierd being REALLY tall, not handle on a trails at all, but hopefully provide some in powder.
Is there a ratio of ground level to suspension points either on the front or rear that makes sense or anything like that? Thanks a lot guys!
