yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
I am hoping some one may have a web siteor online manual that will help me re-build a fox float x shock off an rtx SE.... i have the oils and re-build kit but i have never opened up a float before... any help would be awsome!
thanks
thanks
arteeex
http://service.foxracingshox.com/powersports/index.htm
This should take you to the rebuild instructions for the Float and Float 2.
Try rooting around in the Fox site to find instructions for the Xs.
By the way, a basic rebuild of your shocks by Fox is fast and relatively cheap.
ahicks
yukon yamaha said:I am hoping some one may have a web siteor online manual that will help me re-build a fox float x shock off an rtx SE.... i have the oils and re-build kit but i have never opened up a float before... any help would be awsome!
thanks
That's a scary thought, but I got through my first OK, kinda anyway. As a shock building rookie, have managed to be pretty thoroughly soaked with shock oil on several occasions so far. Best laid plans...
Wear safety goggles/glasses!!!!
Anyway, are you equipped to refill the shock with nitrogen at about 200psi?
Mr Sled, would you post the above link in the "Stickys". Thanks for the link arteex, sweet info.
yukon yamaha
- Jan 30, 2008
AWSOME thanks guys, yeh the shop has all the tools but we have never set about working on one of the shocks, we usally send them out, but being up by alaska frt is a killer!
