tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
I bought a brand new 09 Nytro black and red last January right off the show room floor. I took it out for 1 ride down a perfectly groomed trail for 162 miles and parked it and has been parked ever since.
I just ordered and installed bergstroms triple point carbides with ski saver and 3/8 shim. I was on the phone with him while doing the installation so the installation went perfect.
come to notice after I was done, the entire left ski is tilted towards the inside of the sled and the ski is resting on the center and right carbide. you can clearly see that the ski is tilted towards the inside even with the handle bars straight.
How did this happen or why did this happen. Am I going to have to some how adjust the camber? Is there a way to do it on that sled.
I had the same problem with my SRX when I put on his set-up but I adjusted the camber on the SRX with the radius rods.
Please help.. Tom
Please help.. Tom
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
i talked with scott bergstrom today.
He told me that i could try removing that ski from the sled and re-installing. He said maybe there is something binding in the hole
Any other suggestions appreciated.
skidooboy
other thing you can do is rock the sled side to side and see if one side was weight and swayed alittle when you checked. this is especially the case with light weight stock front springs or without the sway bar in place. ski
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
it also sounds like the dealer did not align your skis (toe in/out) when they setup the sled
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
My uncle is taking the sled to the dealer to get checked out next week.
I was told about some 08 nytros having problems with problems up front not sure what hey were but whatever it is, i hope the dealer can fix it
