Justin Sinclair
Okay a bunch of us went on a big ride last night, We ended up hitting some mud/water holes that where on the trail and you had to go through them to continue. The deepest one maybe came to the top of my tires. Well there was a series of 4 of them and as soon as I got through the last one my grizz shut off. Well this isn't uncommon and is becoming a big pain in my A$$..This same thing also happened about a mounth ago at Hatfield and McCoy's while playing around in a creek. So to point out the obvious this is more than likly a water problem. Well a Brute Force pulled me up the trail a little bit till we hit an open field and a good place to take a look. Well I checked everything and pulled the plug and the top where the plug boot plugs in was all muddy..well I had an extra plug and put it in and it fired up, So I'm guessing this is the problem but what is there to do to fix it, I've already packed it full of dielectric greese and that didn't help, Could there be a short somewhere?..I'm just a little stumped b/c a bunch of us went through a river last weekend and had water up over my fenders and never had a problem, but the little tiny mud holes stop me...Any suggestions? FYI did the air box lid between the seat and gas tank trick and have a jet kit and uni filter
Ganz
- Jun 5, 2004
- Deerfield Wi
- Deerfield Wi
Take the plug off the servo on your front diff and pack that full of dielectric grease. Sometimes if that's not sealed it will cause your problem.
