bluduc
- Aug 21, 2007
ATTAK W/164 1.45 WOODYS ULMER STILL CANT HITCH UP !!ANY SUGGESTIONS??
HONDAFIXER
Are the studs down the middle?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
transfer rod setting!
Turk
Tech Advisor
Wait for snow conditions to set up & harden.
bluduc
- Aug 21, 2007
Yes studs down the middle doubles & singles ulmer stage 2 w/gear change
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
For best hook up the studs need to be outside as well. Mine hooked great last season for the one weekend I rode it with the studs. This year may be different with the Stage 2 and gear change. Your transfer rod setting will also help a lot.
LazyBastard
SNOW!
If there's nothing to latch onto, then no number of spikes will latch.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
How true LB. Mine is sitting in the trailer waiting for snow. Raining here now for the past 2 weeks and no snow in the forecast.
bluduc
- Aug 21, 2007
plenty of snow here(n.mich) got spanked all w/end by 2008 700 s/back,2006 mxz 800
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
You should be beating both of those sleds
LazyBastard
bluduc said:plenty of snow here(n.mich) got spanked all w/end by 2008 700 s/back,2006 mxz 800
You have TOO MUCH POWER.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
You will be impressed with 1.45" studs just on the inside.
HONDAFIXER
Studs down the middle do not work well for hooking up off the line. The tend to dig a trench
BADSLED
- May 13, 2004
- Syracuse, NY
HONDAFIXER said:Studs down the middle do not work well for hooking up off the line. The tend to dig a trench
You would be surprised how well 1.450" studs hook up vs. 1.325"....
