need warrior help
rockafilla156
i get a slight clunking and dragging feeling from what feels like the front of the under carriage near my drive axle. what could this be? i don't see a problem with the drive bearings and there is not vibration from the exaust. also my sled is low end boggy sometimes back fires. and it will not idle on start up. i have set the idle at up to 2300 because at the stock setting of 1350 it idles to low and shuts off. also the sled is always cornering with 1 ski in the air and very hard to handle in deep snow. what should i make for suspension adjustments to fix this? any help is greatly appreciated. thanks
for the dragging, check the slider plastic and all the idler wheel bearings.
the way it is idling sounds like plugged/dirty pilots. good carb cleaning should clear that up.
i would suggest a 12 or 13mm swaybar from pioneer to help with the ski lift problem.
for the deep snow, we need to know exactly what your problem is to point you in the right direction.
i would start with the carb cleaning 1st and check the sliders.
sliders are good and just recently cleaned the carbs. as far as the deep snow problem goes it is pretty much the same as corning with one ski in the air all the time. if i try and turn left not matter how far i lean the sle want to push through and roll to the ouside. unlessi stand completly on one side of the machine. b the back of the sled seems to be kinda low as well.
