furg69
Just wondering if anyone has info for drag racing classes. We are having some friendly races for our winterfest this saturday, and are uncertain of how to set up each heat and how to determine who moves up to the next heat in that class. we will be having 380cc up to 1000cc mod classes. Would there be sheets anywhere online to fill in to simpify the 1st,2nd, 3rd places bases on a points system.Also some people argue what classes the fx Nytro, rx1 and apex belong. Thanks for any help.
Fx nytro belongs in the 700cc class and the apex belongs on the 800cc class. Depending on the race, ive seen the RX-1 in either 600 or 700cc. How many lanes will you be using? If its 4 lanes top 2 generally advance to the next heat (if only 3 racers in a particular heat the top 2 still advance, hope that helps a little. I have all the ISR rule books as well in case you have any more specific questions for each class
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
FAN JUNIOR CLASS
12 TO 15 YEAR OLDS
STUDDED AND UNSTUDDED (340 TO 550 CC MAXIMUM STOCK SLEDS)
LIQUID JUNIOR CLASS
15 TO 17 YEAR OLDS
STUDDED AND UNSTUDDED (600CC MAXIMUM STOCK SLEDS)
UNSTUDDED CLASSES
STOCK 500
STOCK 600
STOCK 700
STOCK 800
STOCK 1000
UNSTUDDED IMPROVED CLASSES
IMPROVED STOCK 500
IMPROVED STOCK 600
IMPROVED STOCK 700
IMPROVED STOCK 800
IMPROVED STOCK 1000
UNSTUDDED OPEN/OUTLAW
STUDDED STOCK CLASSES
STOCK 500
STOCK 600
STOCK 700
STOCK 800
STOCK 1000
STUDDED IMPROVED STOCK CLASSES
IMPROVED STOCK 500
IMPROVED STOCK 600
IMPROVED STOCK 700
IMPROVED STOCK 800
IMPROVED STOCK 1000
STUDDED OPEN/OUTLAW
PRO-STOCK, NITROUS AND TURBO (MUST HAVE FULL LENGTH SKI’S)
UNSTUDDED AND STUDDED
12 TO 15 YEAR OLDS
LIQUID JUNIOR CLASS
15 TO 17 YEAR OLDS
UNSTUDDED CLASSES
STOCK 500
STOCK 600
STOCK 700
STOCK 800
STOCK 1000
IMPROVED STOCK 500
IMPROVED STOCK 600
IMPROVED STOCK 700
IMPROVED STOCK 800
IMPROVED STOCK 1000
STOCK 500
STOCK 600
STOCK 700
STOCK 800
STOCK 1000
IMPROVED STOCK 500
IMPROVED STOCK 600
IMPROVED STOCK 700
IMPROVED STOCK 800
IMPROVED STOCK 1000
STUDDED OPEN/OUTLAW
furg69
i always thought the Fx Nytro to be a 600 class sled. it's only 130 hp
kingedwards99
furg69 said:i always thought the Fx Nytro to be a 600 class sled. it's only 130 hp
Thats the way ive always seen it as well! the old nytro the 120 hp or vector runs the 500 class around here the fx nytro 600 class, ive seen the apex run in the 600 class before i think it should be the 700 class but the fx nytro 600 or 600 improved! Even in the ams oil shootout it runs with the 600s.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
you must find out from your local snowmoble association that is holding the event on what class you fall into, in my case my nytro fell in the 600cc class. from what Ive found out there are 2 different sets of "rules" one were the nytro is a "600cc" class sled and another were its concidered a "140hp" sled (concidered to be a 700cc machine)
gmfamily2008
AnythingButLast said:Fx nytro belongs in the 700cc class and the apex belongs on the 800cc class. Depending on the race, ive seen the RX-1 in either 600 or 700cc. How many lanes will you be using? If its 4 lanes top 2 generally advance to the next heat (if only 3 racers in a particular heat the top 2 still advance, hope that helps a little. I have all the ISR rule books as well in case you have any more specific questions for each class
ISR places the Fx nytro in the 500 class. (HP to weight ratio I guess) typically it runs in the 600 single pipe, and Apex in the 600 multi pipe
- 6K
