Well i have a stage 1 coming from MPI, and i am thinking about doing the install my self. Anything i should be aware of ? Or any good tips ?
Also it's for my Warrior.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I read the directions a lot. I also printed them out and nailed them in order on the garage wall. That helped because you will use the pictures.It's a pretty easy install. Works good cause you will understand the system more by doing it yourself. HAVE FUN AND HANG ON.
Yes read the install instruction carefully. I read them 3 times then started the install. Check them off as you progress, take your time and be very fussy. When you crack that throttle this winter you will have a grin from ear to ear.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I would second the grin from ear to ear, You are going to love your sled after the up-grade. I installed mine myself and it wasn't a real big deal, they have great instructions. Just take your time and when you are done you will understand it all a little better since you did it all yourself. The saying is true that once you run a sled with BOOST you will never go back!!!I can't wait for the snow to fly.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
You'll friggn love it man its addicting especially if you add the BOV and get that noise and the small whine of the blower. Sounds just MEAN coming over a hill and on the trail!
Sounds good, Blow off valve is comming with the kit can't wait
