mdwils
Just picked up an 08 Nytro MTX, going to be used as a flatlander sled around 1500'. Wow, do these things need clutching. With the stock setup AND the drag n fly I've been farting around with tonite, I still cant bring the belt to the top of the prim. sheave. Best I can get is about 3/4 inch from the top and dont want to add more weight to the tips of the weights. Is this the nature of these beasts?
Sled is stock, using the red Heel Clicker DnF spring, I cant remember off the top of my head what I've got for screws and washers in the weights but I've got screws in all the holes except the inside.
Somebody with a good baseline flatlander Heel Clicker setup would be ultra deadly! Thanks
Matt
Matt
Turk
Tech Advisor
You should be seeing about 8900ish at wide open throttle. How have you got yours set up now & what are rpm,s. Gotta have way more info!
