new to RX1
josepy121380
Allenton, WI
Anyone have instructions on how to load the secondary 10 degrees tighter. also is there an easy way to get rid of the annoying reverse beep.
LazyBastard said:
1) Open remove the cover and put the spring in the next hole tighter.
2) unplug it, but this is a bad idea in case you accidentally leave it in reverse as there is no speed limiter in reverse.
what cover? where? sorry i am new to the rx1 and how it works.
maybe ill leave the reverse alone.
Remove left side panel remove the three bolts holding helix to secondary being aware of the # position that the spring is at then add another ten to the twist.push helix back to position tighten the three bolt's.
thanks a lot guys
Here is some info for you I was doing some runs with my sled and jumping up some jets makes a world of difference. The wideband was at 13.6 i would put it at 12.6-13.0
Ohhhh how bad wold that suck go to take off your weight pushes you onto the throttle even more and your back right into something at about 30 MPH LMAO I bet it has happened. I have a Polaris 4 wheeler and in reverse they have a rev limiter but even with that if you are standing and hit it in reverse it pushes all your weight onto the hand that is controlling the throttle
JDMCRX said:
Also the rev beep take the cover off and put on a piec of 1" by 1" foam tape over it mine i can hear but its not supper loud its pretty quiet
thats even a better idea. the damn thing is so loud.
Wideband is a from of O2 sensor that measures air/fuel ratio. Narrow band O2 sensors come standard on every automobile made in the past 15 years or so and are not nearly as accurate as a wideband.
When JD refers to the wideband at 13.6, he means the air/fuel ratio is 13.6:1 which is pretty lean (much more air than fuel) most engines are stoich (average) at about 12.6:1. So basically he added more fuel with the larger jets to bring the number down.
This is the one I run in my turbocharged race car, it's a very valuable tool for tuning.
well i did this first attepmt i fudged up and didnt twist the spring to the right and tighten. i just put it staright on with no load on it. did it again and seems good now. will see tomorrow.
