Dave385
- Nov 12, 2017
- Michigan
- 2018 Yamaha Sidewinder
2008 F1000
2007 F1000
2007 F1000
- Lapeer Michigan
Thank you,Just received my gear in the mail today! Going on my sled this weekend. Thanks Dave. Looks like a solid product.
Let me know if you have any questions
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
FleuryPerformance
- Feb 23, 2019
- Alma
- 2018 Yamaha Sidewinder MTX LE 50th
Hi Dave, I was wondering what is the alloy of your DMC gear ?Thank you,
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
Dave,We are working on the Viper gear
Is the Viper gear still in the works?
Thanks!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Great mileage out of that top gear bushing for sure!That gear has 10,000 miles on it.
I was expecting it to look like my buds' at 4000 that was completely shot.
I bought the bushings you suggested.
My plan is to see how the new gear with 3 holes works.
Next year i'll put the new bushing in & every year after that just put a new bushing in.
I'm going to MIC the results & record them.
I will definitely pull this chain case apart & tear through it EVERY year
I did notice how the center post is worn, i think from a loose chain, so this tensioner HAS to be checked regularly, but it's a PITA when sled left up North.
BTW: If anyone is interested, i use Amsoil Chain Oil & a touch of NRG Release above the sight glass with tension 1 turn out when i check it which will be A LOT more now that i've seen the inner workings of this case.
I too think that a loose chain may cause that middle post wear, but that dam small diameter on the stock 21T gear is also to blame! Compare the difference when 22T is put on. It allows the chain more room away from that post with it’s wider diameter!
I did that same post damage on mine with under 1000 miles on it, six years ago! Gear is just too small, so I changed to a 22T and added a tune back then! No more wear since!
As pointed out to me by others! It can only wear so much without going too far and causing it to hit the bolt in that post maybe, and at that point it’ll probably start to leak oil from that worn post!
Reason you don’t hear about that from our Cat side, their top gear is much bigger!
Ours 21/41 theirs ??\38
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The tcats are 24/50Great mileage out of that top gear bushing for sure!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanx!The tcats are 24/50
