Avalanche
What is your opinion on this for an Attak, I run my Fox Float between 40 and 45 psi for the best cornering. Thanks
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
They are awesome on my fx nytro, have mine set at 75 psi, and they are still soft and compliant through the stutters, and no loss of suspension travel.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
I'm also running mine at 75 psi, w/ screw out 25 turns. I like it far better than running stock with 50 psi. Getting a lot more travel out of the shocks than you would running lower psi........also the big hits on the front end don't seem to hurt as much. That being said.....now I feel the shocks should be re-valved...........
kingedwards99
where do we find these at? Where's the best deals for them?
Nytro40th
- Sep 19, 2007
carbonsled.com sells them. Check out there site.
Do they just hold more air ? If so is it possible to use the "cans" of a normal fox piggyback clicker shock and add that as a extra air reservoar?
Kråkan
Bengan Motor has a kit in sweden. Have them and the floats are better with them. kost was something like 700sek if im not remembering wrong.
Nytro40th
- Sep 19, 2007
nextech also includes a valving shim and bushing that you place inside the shock. $300. cdn
