Nitrous nozzel location on MPI
1CrazySledder
Cartersville, GA.
None, looking now!
Wondering where you guys are mounting the nozzels. Directly on top of the IC, into the intake charge tube just before the IC, or into the intake rubber tubes? ( In between the IC and the butterflies ) What has been your results with what HP shot.
I will be upgrading to a Stage II with Nitrous for next season, so I am starting some research now. I understand I will have to change out the rods, pistons and headbolts, fuel pump. I am also thinking about adding a Water/Methanol or just Methanol injection as well to help with octane numbers.
Any input would be great. Thanks.
-Vince
BRO.............Run the NOZZLES right into your helmet :jump:
I swear if you had 1,000 HP on Red October you would still be lookin 4 more BOOST. ;):D
I'm just Jealous Bro........I would love to see this sled when it's running, it would certainly B AWESOME :Rockon:
I'm starting to look at a S.C. 4 Me next, you guys are killing me with ALL THIS BOOST POOP :flag:
BTW Vince......A guy here has a 750HP Nytro Methane 4 Stroke Monster :-o
That’s where I put mine (picture and parts in the first link) but I wouldn't run more than a 50-shot from that location because of dispersal concerns ... I've run a 100+ pounds at 30hp to 50hp with no problems ... Gives me 500 to 800rpm depending on clutching and the ratio of fuel I run with the nitrous ... Couldn't believe the difference not enough or too much fuel makes in the rpm ... At one point I had it set up for a 30-shot and it would slowly creep the AFR up to 12.8:1 pulling harder and harder as the AFR climbed ... Last week I got about the same rpm gain with a 50-shot at 11.8:1 ... Just be careful ... It's easy to hurt stuff with nitrous.
http://www.ty4stroke.com/viewtopic.php?t=44259
http://www.ty4stroke.com/viewtopic.php?t=45620
We are going to try this on my MPI Stage 1 Nytro. We are going to into the charge tube just before the IC. I was wondering about trying a second stage in the top of the IC? Not sure how much this stock motor will hold?
