stricklandj
- Feb 21, 2010
- Nova Scotia, Canada
- 2013 Yamaha Nytro XYX 1.75
Had my sled re-valved, hygear triple and double springs, and set-up for my weight (170lbs). Limiter strap second hole, and min transfer. Don"t have any ski pressure which doesn't make sense. Any suggestions. Will contact the guy who did my work on Monday but riding tomorrow and would like to try some things.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Soften/shorten up the center shock and pull your limiter up 1 more hole.
dansranger
Do you have a lot of preload in the center shock?
You might want to check the rear suspension. Maybe the rear arm is backwards?
stricklandj
- Feb 21, 2010
Rear arm backwords?
