Non boosted mtn apex clutching
thistle
Alberta
Anybody try or come up with anything that helps make the sled work a little better?? I ride 5 to 7000 feet mostly. I did add a touch of weight to the tip but that was all??
Anybody??
I ride at 10-12,000 and all I did to mine was crank up the preload on the secondary to get quicker back shifts. It works great, turns 10,800-11,000 all the time. In fresh powder it will hit the rev limiter (11,200) every once in a while. Eric
best thing you can do to that sled b is put polaris weights in the primary and a hyperlite secondary on it!!!!!!! just so happens i have done this to mine and it works awsome! the less spring pressures you run in both clutches the more eficient the sled is going to be.
dallas
Put a Hi-tech ER roller secondary on my Dads and that seemed to help, it also doesn't slow down as fast when you jump out of the throttle. I'm running the same setup on my boosted Vector.
Dallas, did you run that setup on a stock sled or turbo'd??
