Noses 'n sounds of a new machine
mateo
BC
Well, not new, but new to me. 400 miles on the machine.
I pulled out the foam in the pannels, re did the drivers, and track.
After I put the chain case back together, the disc brake has a bit of loose in it. about 1-2mm. I figured it might be normal - can someone confirm that?
I think that maybe with the play, it's rubbing somewhere and making a strange sound.
I was wondering if all the noises associated with riding this machine are normal. For example the whine when going down hill.
thanks,
m
You will have better luck asking this question in the fx nytro general section.
This is the project/garage/showroom section of the forum.
The whine going downhill could be low gearing, or too tight chain.
