Quadzillaracer
Just wanted to take the opportunity to inform some of you 4-stroke guys that may be interested in professional 1000' speed runs that the old NSSR is finally back with new owners after an almost 8-year absence.
As many of you know the old defunct NSSR had a strong long run but ended around 2001. Then CMSA (Central Minnesota Speedrun Association) came to the rescue to give speedrun guys a home to continue on. Now fast forward to early 2008 which brings new owners Ron and Stacy Bray to bring back NSSR for 2009. They have dedicated an incredible amount of personal time into this venture adding ISR 4-Stroke Classes to bring in new racers. Last season seen "3-new" 4-Stoke ISR World Records placed which will be the bar to beat in less than 3 months!
ISR 1000' 4-Stroke I.S. Record: 138.019 mph in 1000'
set by Shanon Disch on a '04 Warrior Simmon's Turbo setup
ISR 1000' 4-Stroke Pro Stock Record: 153.xxx mph in 1000'
set by Jack Henricks on a Simmon's CPR Turbo setup
It would be nice to see even more 4-stroke guys at upcoming NSSR events in 2009 to raise the bar even higher on those records, plus you recieve 4-pass tickets for the day, so its not a one shot deal. If you'd like more info. dates, rules, ect see: www.racenssr.com ........hope to see more of you guys in 3-months! Wow thats soon.
EDIT!!! I apologize if somebody doesn't like this post in this section, just thought it would be a good spot with all the Turbo/Supercharger guys here.
